1 - 20 of 34 Posts
Need a trailer hitch for my bike rack. I have a stock 2006 SSR with the stock wiring and hitch accommodations. I am in Naples Florida. I do not need the ball. Anybody have one for sale or know where I can get one?
@ ssroe from GA had 3 for sale at Maggie Valley hopefully he will read this and get in touch with you.
:black:
:purple:
Krazy Ed
Hey I’m looking for a hitch for a bike rack for my 2004 ssr. Do u know of anyone that can help me? Appreciate it
Thanks.
Thanks.
From what I have seen on here over the years you have to make part of it so it has a square receiver tube to slip the rack into. The trailer hitch made for the SSR slips into a spot under the body and has a ball attached to it.Maybe someone that has made one up will jump in and help you or use the search button up top. Good luck.
I know there are a couple threads on making the Hitch insert handle a 2x2 square insert but have not found one yet. If I find one I'll post a link in this thread.
DSTRSSR
I have a bike rack that will bolt on to a bumper or the hitch (instead of the ball)
I got this plan from SSR3. He helped me make this one. I use it to hold the American Flag in our parades. He uses it to hold his spare tire. It looks great.
This Bike Rack bolts directly to the Trailer Hitch using the Ball and works fine for short trips.
Simple "Plug and Play" with no modifications required.
! :surprise: ! :cheers ! :surprise: ! :cheers ! :surprise: !
I had this one made for a 2" receiver. It bolts directly to the stock SSR hitch instead of the ball and is then further secured through the safety chain loops. It is available for $40.00 plus shipping. I'm in KY.
@Railroad Guy, I assume the bottom of the insert is notched or cut off to clear the bolt
head to slide in enough for the pin, or is the bolt head cut off and the shaft welded to the Receiver?
Bicycle rack hitch mod
Here is a pic of what I did to solve the bicycle rack issue.. Not an expensive mod and works with all my towing needs
:silver::silver::silver:
1 - 20 of 34 Posts
