:confused I wanted to know from the people that have changed there own oil. What did you do to lift your vehicle high enough to change the oil. The ramps that I have are not wide enough. Please help me!
You can do it either way, although it gets tricky jacking in the center if you have a small floor jack. Nicer jacks with a larger diameter saddle make this easy, though.
The thing to remember is to be safe. If you are more comfortable jacking a side at a time, do it that way, making sure your jack stands are absolutely secure before crawling under the vehicle.
