I'm bugged about what the purpose of the verticle oriented sleeve piece on the forward driver's side of the console is for. It looks like the same piece that is on the passenger side for the accessory cup holder but is oriented to receive what ever is meant to slide into it from above and not from a horizontal direction as for the accessory cup holder mounting bracket on the passenger side. Do any of you have this on your '05s? It seems to be molded into the plastic flashing that is on the driver's side of the console. I have the accessory gauge package...could the side panel be put back together incorrectly after installing the gauges? It only appears to be able to fit the way it is in place now. The bracket can not be moved without breaking some plastic piece. It is not mentioned at all in the owner's manual. Is there an accessory sun glass case that is to slide in there? Cleavermodels
