With all that built in rigidity, is a frame support or plastic front frame piece really necessary?
Just curious. People that install those always exclaim how much better it rides. My SSR feels like it has a floppy kind of suspension action. Feels like I have basketballs for tired on stiff suspension over bumps. I have been contemplating picking up the braces from you to get the suspension to take more of the action instead of the truck wiggling around when I drive over railroad tracks or a semi rough road.
S2NAZ: Your description sounds like I used to feel, and I'd add the word "lazy". The short answer to your question is: yes. But I would also add, the frame, body and suspension are a system. Doing one thing will help, doing more will help more.
I addressed the items in the following order, on jackstands in my garage:
1) LC32 crossmember & Simple Engineering stiffener (2012)
Result: Nice. The head shake was gone and less creaking.
2) Trailblazer cross member. As I recall there no Simple Engineering available at the time (later 2012)
Result: A less creaking. I then used felt tape on many interior panel joints with a result of even less creaking.
3) New Michelins all around (2013). 275/40R19 & 315/35R20
Result: Much more traction all around. I went bigger/wider than stock as I think it gives her a "G machine" kinda look, fills the wheel wells more and the wheels are protected from rash. IMO: It just looks cooler.
4) Addco Front and Rear Sway bars from Simple Engineering (2014)
Result: Less sway, but still felt sloppy and rocked side to side a bit too much. I like your description of "floppy". I kinda thought "that was it" and it best that I could expect without lowering. My thinking is, she's a top heavyish truck, compared to my Z06, and not inclined to lowering. I've done that on other vehicles with mixed results and there are occasions where sitting a little higher is better in Houston.
5) Radiator Support (2015)
Result: I felt better than having the plastic part. It also saved my radiator and me from injury, but that is another story.
6) Bilstein shocks from Simple Engineering (2017)
My thought behind it was the shocks are 11yrs old and probably tired. I had just done the brakes and it was a good maintenance thing to do. I also replaced my front tires a couple months earlier due to a hole.. Time to get the alignment re-checked, etc.
Result: Whoa :surprise:. The rocking calmed down. She's much more planted, solid and stable. I didn't expect that much of a change. Afterward I subjectively realized that one of the rears was nearly flat as there wasn't much pressure relief when I drilled it vs. the others. The new rear shocks are bigger than the OEM, and if I recall correctly the valving is different in them all.
Bottom line:
Don't forget the shocks... I should have done them a long time ago, like #3a?, but I still would have done them all.
