Hi all, just started experiencing this issue this week ... 2 issues actually, as I don't believe they are related:
1. Issue #1 - my power door locks have started to randomly unlock/lock while I am driving. Does not occur with any regularity ... the door locks just UNLOCK - LOCK, sometimes two or three times in rapid succession. What could be causing this? My thought is that there is something in the transmission linkage that is telling the door locks that the car transmission is momentarily in PARK (or NEUTRAL?) and the door locks UNLOCK, but then quickly corrects and the door locks LOCK. Might this be indicating a pending failure of the tranny linkage at the shifter itself? Or might this be related to an intermittent disconnect in the electrical wiring inside the door? Has anyone else experienced this?
2. Issue #2 - When I press the door LOCK button on the center console, my passenger window rolls down!! Same as if I momentarily pressed the window DOWN button and the window cycles ALL THE WAY DOWN! Had this happen as I was going through a car wash ... luckily the washer was spraying the other side of the truck at the time. Any help in diagnosing this is appreciated.
Cheers, Carl
Cheers, Carl
