Welcome to the Group, from Friendswood, Texas.
1. Install the LED lamp upgrade in the Cargo area and replace the 15 amp fuse in the box behind the passenger seat. It can overheat and burn causing a possible fire in Your R. Unplug the cable until this is done to be safe.
2. Purchase and install the Transmission cable upgrade. Don't get caught in the middle of nowhere and have it malfunction and have too crawl under the truck too shift into drive.
3. Install the Heat Shield on the ABS system, very easy install and very much worth not having too worry about the ABS unit deteriorating due too excessive heat.
4. Have the Front end alignment checked and set too recommended specs. Save those tires and improve the handling of the R.
5. Look into changing out the Radiator and Support system, they are prone too failing.
6. Inspect the hydraulic hoses in the roof storage area, make sure no leakage is present.
7. Invest in a good Rubber Seal protectant, these parts are getting harder and harder too find, protect what you have.
8. Keep visiting the Forum and asking questions, sharing information You find on your own, You will love the R and learn from Others experiences.
9. Look into the upcoming ( October 2019 ) International SSR Rally in Branson, Mo.
10. Contact Me with your information so I can send You the Drive which contains all the information on The R. Service Manuals, Common problems and other useful information. I have One extra and will send free of charge cause You're a Fellow Texan..lol
11. Enjoy, Enjoy, Enjoy ( Secretly, You did purchase the BEST Color, don't Listen too these other guys and gals..lol )
