What's up with No spare tire?? Or am I just blind??
GR :cry
GR :cry
No spares and they're not run-flats. I get a flat about once every 2 years, always on new tires, so it's kind of a pain.Ghostrider said:What's up with No spare tire?? Or am I just blind??
GR :cry
Have you ever used one? Don't you need to pull the tire off the rim first?wildcat66 said:It's All Good!!!! Can you say warranty!!!!! Someone posted a great tip. Carry around the Plug kit, We use them all the time when available.
Flassh said:Won't work Tahoe,
Bottom line, you need the overall diameter of the rear to be the same as original, because the Torsen rear end will be damaged by unequal diameters. The large diameter won't fit the front wheelwell.
Ray
