1 - 18 of 18 Posts
Slingshot Yellow 04 SSR Automatic 10086
This is my first post. I am actually looking for an RGang located near me. I've had my Yellow 04 SSR since September and really enjoy driving it. I've enjoyed reading a lot of the posts; there's a lot of knowledgeable owners here. I'm looking for someone with experence working on the top hydraulics to R&R the 2 main cylinders. I understand i will have to remove the cylinders, send them to get rebuilt, and then have the reinstalled. I am located in Salisbury. NC which is about 1 hour from Charlotte and about 2 hours from Raleigh. Any infor very much appreciated.
· Premium Member
@Buckster, some one will chime in shortly, Meantime--Welcome from Forney Texas. Consider clicking on the Colored Letter/Picture, top far right corner, go down to "Account Settings", click, and fill in your information. Especially your LOCATION and the year of your SSR, like the rest of us. Then go the the left side and click on "Signature". Also put the year of your SSR in your "Signature", and anything else you want to show in your posts, and we can help you better if you have a problem. When you finish click the "SAVE" box.
Click here for parts, help and tips--Simple Engineering, LLC – Chevy SSR Aftermarket Parts, Accessories and Repair Solutions
Owner Pinmap locate other owners and let them locate you. Go to last page to add your information.
How to navigate our Site FAQ
Nick & Kathy
If you're handy like most of us, you can remove the cylinders yourself and ship them off to Cabriolet Hydraulics in Sarasota Florida. They'll rebuild them and ship them back to you. If you'd rather have someone else do the work, you could plan a short vacation and take a ten hour drive to visit Sarasota and enjoy the spring season while Zig and his team take care of your leaks. Or... You could arrange to visit the Rgang and get some hands-on experience while fellow fanatics help you get rid of that pesky leak.
· Premium Member
2005 Chevy SSR,2004 Ultra Violet
Rgang can help you but you would need to make the drive to Orlando area as others have indicated. Let me know if you are interested and I will start a conversation with so we can talk.
· SSR Pit Crew
2004 Silver SSR with Strips. Owned 19yrs. Start 9K, now 166K miles
· One of the SoCal Nuts
Others have mentioned starting a Conversation with you and you will be able to answer that but if you wish to start a Conversation on your own you will need to get some more posts under your belt. The best way is to get to reading and if you have a question, Ask it!!
Welcome.
Discussion Starter · #9 ·
Cylinder Removeal instructions on How to Library: SSR - OneDrive (live.com)
Look up: ROOF CYLINDER REMOVAL 102420.pdf - Microsoft Word Online (live.com)
Send to:
Cab Hydraulics, LLC
2111 72nd Terrace E
Sarasota, FL 34243
(941) 756-1300
Zig Paul Owner (Zig has 2005 RED SSR)
Thanks Dictator! When I first started reading on SSR Fanatic I kept reading that I didn't need to change all 8 cylinders at the same time, only the one leaking and the same one on the other side. Now I'm reading to change all at the same time becaust is such a job and most are saying it's only a short time before other cylinders will start leaking. Which of these do you think is the best; I do appreciate your advise.
· The Susan Lucci of ROTM
2004, lowered, custom paint
All cylinders are not necessary at this time. There are 8 hydraulic cylinders and 2 helper struts. The two main cylinders do the main lifting and take more stress. The helper struts assist the weight of the roof on the main cylinders. Now that being said, everything ages out so I suspect the other four cylinders that operate the flaps will become an issue down the road. As of right now, I've only heard of a few of those needing rebuilt.
All cylinders are not necessary at this time. There are 6 hydraulic cylinders and 2 helper struts. The two main cylinders do the main lifting and take more stress. The helper struts assist the weight of the roof on the main cylinders. Now that being said, everything ages out so I suspect the other four cylinders that operate the flaps will become an issue down the road. As of right now, I've only heard of a few of those needing rebuilt.
There are also two hydraulic cylinders that latch and lock the tonneau cover for the roof compartment, for a total of eight. In the brief three and a half years that I've been reading the posts in this forum I recall just one person mentioning the "Latch/Lock" cylinders as having a leak in a new post. I agree with you in regards to not rebuilding a pair of non-leaking cylinders. The Main Lift Cylinders do the heavy work, and those are the cylinders most prone to leaking. Replace the pneumatic lift struts at the same time that you rebuild and replace the main lift cylinders. The assist struts help support the load as the main lift cylinders raise and lower the top. With so few reports of hydraulic leaks in any cylinders other than the Main Lift Cylinders, I'd think the philosophy of "If it ain't broke, don't fix it" applies.
Discussion Starter · #13 ·
There are also two hydraulic cylinders that latch and lock the tonneau cover for the roof compartment, for a total of eight. In the brief three and a half years that I've been reading the posts in this forum I recall just one person mentioning the "Latch/Lock" cylinders as having a leak in a new post. I agree with you in regards to not rebuilding a pair of non-leaking struts. The Main Lift Cylinders do the heavy work. The assist struts help support the load as the main lift cylinders raise and lower the top. With so few reports of hydraulic leaks in any cylinders other than the Main Lift Cylinders, I'd think the philosophy of "If it ain't broke, don't fix it" applies.
Thanks for the info, I agree.
Discussion Starter · #14 ·
Thanks Firetruck
· SSR Pit Crew
There are (8) Hydraulic Cylinders, (4) Solenoids that drive hydraulic cylinders. Each Solenoid drives TWO hydraulic cylinders that is why they MUST be rebuilt in pairs. Can't' buy NEW ones!!
Yes, TWO Main Roof Lift cylinders usually leak first because they do the "heavy" lifting. BUT would you rebuild your (8) cylinder engine TWO cylinders at a time? Cab Hydraulics will rebuild cylinders in pairs.
I recommend that you rebuild TWO main lift cylinders first. Yes, I did all eight on mine ten years ago.
PLUS, our Roof has TWO pneumatic cylinders that "buffer" lift and lower to extend the life of the hydraulic cylinders.
How do you know that pneumatics cylinders are bad? Lower the Roof, when it gets within 3 inches of open, IF roof goes "KLUNK" you have BAD pneumatics. CHANGE THEM!! You can order from Mike aka Simple Engineering. Don't wait!
Roof like R is 20 years old or almost. I go to doctor more often than I did when I was NEW!!
Parts and Support: Simple Engineering, LLC – Chevy SSR Aftermarket Parts, Accessories and Repair Solutions (simple-engineering.com)
Roof Repair Solutions: Cabriolet Hydraulics
Email: [email protected]
Oops.... Forgot about those two buried in the sidewalls with the micro switches. Thanks for the correction!
Discussion Starter · #17 ·
Thanks Dictator, no KLUNK so I'm just going to fix the 2 main lift cylinders.
Discussion Starter · #18 ·
Hey Dictator, Thanks again, not just for the info, UT for convincing me to do what I already new was the right thing to do (rebuild the whole hydraulic system). Question: should I have the pump rebuilt also? I don't know what at age they usually go bad. Thanks in advance for all advise!
1 - 18 of 18 Posts
