1 - 20 of 26 Posts
Has anyone here experienced this strange vibration that only happens at highway speeds of 65 plus. It is like a wheel out of balance but has a "pattern" to is and is not the routine bouncing. It has a cycle to it. Man this is hard to describe. Anyway most likely is a bad tire and I have scheduled the dealer to do a road force balance job to find out what the deal is. I how have just over 900 miles on the 05 6speed.
Any ideas?????:banghead
Banned
Not so far but where are you feeling it? In the wheel or in the body or seats? I think the right place to start is to have the wheel/tire balance checked then go from there.
I know the feel
Slight vibration in a steady repeated pattern. I have had it since day 1.
I did in fact have the service center rebalance both front at 150 miles and it became considerably more tolerable.
Discussion Starter · #5 ·
C1Trob...that is it exactly... a steady repeative pattern.
Smokin' Joe...now if you are goin' hang here you gota read the post first...I indicated I have already scheduled the road force balancing!!! (just kiddin") by the way dude..I drove Nascar for almost 7 years in Richmond, Va. years ago. I dorv cars owned by Junie Donlovey if you remember his name (this was before your time)..So you will know he owned the Winston Cup cars that Dick Brooks drove the old number 90 . Do you remember that ??? I drove back in the late 60's at Southside Speedway and shared a garage with Lennie Pond who won Talladaga in 1973!!!
Sorry for the rant
See ya guys:lol
Yep, I've heard/felt that.
It's the tires/wheels. In my case it started after I bent a front rim. A simple matter of slipping of the edge of the pavement at about 40mph. This also caused a misalignment.
Rebalancing fixed some of the problem, but I should have had the front end realigned too. That failure to act, lead to unevenly worn tires, with the result of both wheels vibrating at different frequencies. It's the differing frequencies that beat against each other and cause the vibration to seem to come and go.
To be clear, a wheel speed vibration, that comes and goes, means that more than one wheel/tire is out of balance. If they are worn badly enough no amount of balancing will fix the problem.
In order to reclaim that silky smooth ride, I had to replace all four.
Vibration
had a vibration but didn't seem to come from a wheel. My Dealer replaced the drive shaft and it went away.
If you feel this cyclic pattern in your seat it may be the rear wheels that need to be balanced. If you feel it in the steering wheel it may be the front wheels that need to be balanced.
Reactions: B Rad
A little of both
The cyclic pattern is known as a beat frequency in electronics. It is the combination of two frequencies that are different. Perhaps you have a slight imbalance in a front wheel (smaller diameter, higher frequency) interacting wioth a slight imbalance in a rear wheel (larger diaeter, lower frequency) that is producing the repetitive cyclic vibration.
I had it in mine and Freeway Chevrolet did a force balance on all 4 wheels and it went away. They moved a small amount of weight on one of the fronts and removed one of the stick-on segments from a rear........
Mikey
Discussion Starter · #11 ·
Thanks for all the replys. Mike, I think you hit it on the head...I will get into the dealership when the snow stops so they can get it fi:seeya xed.
Root cause requested
When you take it to the dealership, tell them you want to identify which wheels were out of balance and how far. They should be able to tell you exactly what each one looked like coming off the truck and then how much they had to change to get each wheel in balance. Post a quick reply here to document your findings. It is really good to close the issue out.
Regards,
RetroCarGuy530
I posted in another thread about this very issue with my 05 SSR. I had out of round tires on the front (both) and even after having them replaced I still had the "out of balance" vibrations in a cyclic fashion.
I found a shop that could perform "road force balancing". It cost quite a bit more than regular balancing, but it was well worth it in my case. They find out how much road force is being produced as the tire spins and the balancer will identify how much to move the tire on the rim to hopefully greatly reduce the amount of force produce by the tire and thus (likely) far less weight to balance the tire/rim combo.
OMG what a diference. I had one of the "new" front tire/rim that was producing over 40 lbs of road force. They stated that below 10 lbs was great and up to 15 would be ok. They were able to drop the road force on that one 40 lb tire/rim down to 8 lbs. I only had one rear tire/rim that was in balance and with 14 lbs of road force and the balancer could not reduce it below the 14 lbs.
When I took my 05 SSR back out on the freeway, I couldn't believe it was the same SSR.
I'm a true believer in road force balancers (Hunter 9700 series I believe).
Hope that helps.
I found that if the top was down at the speed, and the vibration was present,.. all I had to do was scouch down in my seat some and get my ears out of the wind. It also helped if I closed my mouth. When the top is up I have no vibration. I hope this helps. :thumbs
Probably the wrong thread, but
it's worth sharing when you find a solution, as Focks so aptly shows. My wife located the definitive source of the loud squeal at WOT. Only happened when I drove, and my wife swears it came from directly behind the steering wheel! :skep
Discussion Starter · #16 ·
I will certainly keep all informed. It wil be a few days before the dealer will get the truck due to snow that happens to appear almost each weekend including this one. I don't drive the truck in bad weather or wet or salty roads.
Again thanks to all for the help..this forum is great...Incidently not only do I hear this I really feel it in both the seat and the steering wheel. At 70 mph is shakes which makes me fee it is a tire/wheel issue.
See Ya:)
Discussion Starter · #17 ·
Thanks for the "tip" but my ears and teeth are quite abit smaller than yours!!!!
If you have the top down it has to slow you down a good 10mph . This is based on avatar!!!!
Have a good one you "Head Case":jester :jester
See Ya:)
Mine was a slight vibe that started at about 70 and seemed to peak at 85. It had the ashtray (useless device) rattling so much that we had to leave it open. Just the slight rebalance on the wheels solved it. Thoroughly tested it that weekend:eek , as we were traveling in the caravan to Laughlin.:jester
Sorry to hear you are being snowed this weekend.
I have the same problem at around 65-70 mph. The "shudder" seems to more pronounced on cement roadways than asphalt.
Mine was temporary
Last week I had a bad steady, repeated vibration. It happened right after a snowfall. I suspected it was ice frozen to the wheels or drive line. The next day, after it warmed up a little, the vibrations went away. :)
1 - 20 of 26 Posts
