I suspect others will chime in on this and may suggest a "fix."
Don't know if my top problem is peculiar, or if others have (had) the same issue.
When I actuate the top down switch, the first tonneau door begins to lift up and raises about 1-2" in the air and then "times out." However, if I release the brake pedal, as well as the actuater switch while the lift is occurring, and before the "time out", the tonneau door will "pop" up with a thunk. Immediately, I then depress the brake pedal, actuate the top down switch a second time (before the tonneau door settles back to its mooring) and the top will complete its opening cycle with no further ado. Its been acting like this for several years.
I recall reading a post on this forum years ago (browsed as a non-member) when someone may have had a similar problem, and he indicated that when the tonneau door began its upward ascent, he (or likely his passenger) gave the tonneau door "a wee tug" and the top then completed its opening cycle. I used to have my passenger perform the "wee tug" before I learned the trick explained above.
Is there any "fix" for what I've described?
urple:
