1 - 6 of 6 Posts
Need a little input from all of you out there. Short and to the point
I have 1400 miles on my SSR and Im down a quart of oil..........normal
I would not expect that!
Gm's guidelines are up to 1 qt per 1500 miles is acceptable. Did you check oil when you got it? Any signs of smoke out tailpipe, etc? Gm's guidelines say is not a exact figure, due to driving habits, load carried, driving conditions and so on...I would recommend check for leaks, if none seen top off oil or change oil and filter
and recheck in another 1500 miles, if is down again, go to your dealer and
request to start a oil consumption test...
good driving.
I changed oil with Mobil 1 @ 6000 miles-reset oil life monitor-Yesterday turned over 10,000 miles and 64% on oil life monitor. Oil level is about a pint low. I think this is normal.
1 - 6 of 6 Posts
