Somehow Betsy got a big booboo. :cry The problem is on the driver's side lower headlight and the front grill. (THE SILVER PIECE THAT RUN ACROSS THE FRONT WITH CHEVROLET ON IT.) The scraped headlight I can live with but the crack in the grill is bad. I was wondering if anyone knows how to replace the front piece and how much it costs. Haven't been able to find parts list on line that had it listed. I would sure appreciate any input. It just makes me sick to look at it, :nodno but could have been worse, no paint damage. I don't how it happened or what did it, but just makes me sad to see it. :confused Oh well, it's just a truck HA HA :ssr
Sorry to hear about the booboo. I had a rock fly up from a semi in fron t of me and put a gash in mine the first week I had the truck. The part is expensive, about $340.00, with only about an hour or two of labor for the installation. I had to wait almost a month for the part to come in. Best of luck!!
Pulling the front Trim
The brushed aluminum colored cross piece has industrial strength velcro holding it to the front of the truck on each end and there may be a couple fasteners through the front bumper in the center (not sure). If there are fasteners in the center, you need to disconnect them first and then pry the ends off the headlights with a flat tool....... very carefully. You might get the local Chevrolet Body Shop to do it for you if you are unsure of yourself.
Attached is something out of a parts book. Part numbers are right, prices are close.....
Good Luck,
2004 custom Paint and trim , ROTM winner #2, Previous owned R’s, 2006 #1 of 8 2 tone & 2005 silver
Moulding
A new mldg from Chev list for $319.67 and comes with a new bowtie as part of the assy. Can't just by mldg separetly which is a shame because the bowtie itself lists for $116.90.
Very easy to remove mldg assy. GM Part #15234614
Doug
Enjoying life as it comes
Front bar removal
Is very simple and easy.
You'll need a 7 millimeter socket and ratchet or just 7 mm wrench.
There are two screws located just inside the fender under the hood. Once these are removed, grab the ends of the cross bar, one at a time, and pry outwards firmly, but be ready to stop as soon as it releases. Then repeat for the opposite side. You are now ready to install the new bar. Simply slide into place and tap litely to lock in place, then install the two previously removed screws and you're done.
Discussion Starter · #6 ·
It's great to have friends
Thanks guys. You've been a really big help. My husband will order the part and you've given me the confidence that we can install it ourselves. She'll be beautiful again in no time. :cool
:angel I LOVE THIS FORUM< YOU GUYS (AND GALS) ARE GREAT !!! :thumbs
