I've had my R a little over a month and I've been chipping away at the preventive measure projects that this great group on the forum has made me aware of.
Today was the ABS heat shield, "Dicktator" shift kit, and a beefy crossmember.
Tomorrow? The radiator support bracket.
My question is this :
I've read that in the warmer climates overheating can be an issue. Their must be something to it as their are larger and more efficient fans and radiators available. Not to mention the specialist that can tweak the temps that trigger the fan.
I'd like to be bulletproof before next summers Fl heat kicks in.
What have you southern guys experienced with the overheating, and what did you do to deal with the problem.
Thanks Ed
Thanks Ed
