1 - 4 of 4 Posts
2005 Redline Red 6 Speed
Anyone had this code? I removed throttle body spacer and now have this code and truck idles rough?
04 SSR
Does your truck start and run OK.
If so, you may have set this code while removing or installing throttle body. I would clear codes and the drive.
If not recheck connector for damaged pins,wires or loose.
I would also make sure gasket is positioned correctly and did not tear. This could cause your rough idle.
1 - 4 of 4 Posts
