1 - 4 of 4 Posts
2003 Chevy SSR
This only seems to happen in cold weather.
It takes a number of pulls on the parking brake lever to get the parking brake actuated fully. During the first couple pulls, there seems to be very little resistance. After that, I get some resistance, but I need to try a couple more times until it feels firm enough to hold the truck in place. It's like it takes a few pulls before it starts grabbing, but after that, it works normally.
I can't imagine what would cause these symptoms. What's up?
04 SSR
Possible problem with the self adjusting mechanism built into the parking brake lever.
As long as you can get it to work I might not be too concerned right now -
I would be sure and tell trans shop and tow truck driver about the issue!!!
Attached is from the service manual regarding how to re-enabling the self adjuster operation -
(SORRY - No pictures that I could find!)
04 SSR
Haven't used mine in 5 or 6 years ... got it covered up with Turnheads leather "Cup Holder" which is very, very handy.
You should still cycle it on and off a couple of times a year at least - it keeps components from seizing up! Just be careful the next time you do try to use it - it may stick on. Better yet next time you take it in for an oil change ask the techs to check it out for proper operation - be sure to tell them why!
1 - 4 of 4 Posts
