OK $, you got some of it right, but are starting to muddy the water somewhat.I guess I am missing something, which is not unusual! HaHa!
Every SSR has the G80 RPO, so they are all limited slip, not sure what he wants to change that to.
Torsen is the 6sp diff (14") - American Axle for the automatic (10")
Aren't we just talking about gears here?
Am I digging the hole deeper?
Turn off the traction control , step on the brake ,put in drive, apply gas and the permagrin will show up .You know I got to thinkin - best to try out some asphalt after the rain stops. Hope I see 2 black streaks. That will answer my question !
The gear change on my ‘03 was done a couple of weeks after TruckNRod’s ‘05 by the same shop. They strongly recommended that I change the posi gearing on mine. They did not, however, make a similar recommendation to TruckNRod. I can’t really remember what they told me the difference was but surely (not calling anyone Shirley) it had to be related to the difference between the ‘03-‘04 (8.5”) and the ‘05-‘06 (10.5”).I'm new to this forum ,and noticed quite a few rear end gear changes ; but no one mentions changing the carrier to a posi or limited slip. Am I missing something?
'05 silver auto - DDoug
The Torson has no clutches, that's the beauty of it. It's all gears and doesn't wear out like the posi clutches.Thank you all for your insight ; the old school method of checking for an open non posi set up was to turn one wheel and notice which direction the opposite wheel turned. If it turned the other direction ; it was not posi or limited slip, same direction was posi. My '05 turns opposite. So - I checked the tag ; and it does have a G80, so my rear end clutches are worn out?
There are no clutches in a Torsen rear axle......Thank you all for your insight ; the old school method of checking for an open non posi set up was to turn one wheel and notice which direction the opposite wheel turned. If it turned the other direction ; it was not posi or limited slip, same direction was posi. My '05 turns opposite. So - I checked the tag ; and it does have a G80, so my rear end clutches are worn out?
What a great way to explain it, thanks MikeThere are no clutches in a Torsen rear axle......Thank you all for your insight ; the old school method of checking for an open non posi set up was to turn one wheel and notice which direction the opposite wheel turned. If it turned the other direction ; it was not posi or limited slip, same direction was posi. My '05 turns opposite. So - I checked the tag ; and it does have a G80, so my rear end clutches are worn out?
If you want to understand the positraction unit that is in every SSR with an automatic transmission.... Do a search on the internet for “Zexel Torsen” and read up on what is installed. In an operational nutshell....... when there is no power being transmitted through the pinion gear, the Torsen unit acts as if it were an open differential. That changes when you start adding torque to the input pinion. With high torque conditions, the Torsen unit will seem as if it were a live axle with no differential action at all. If you have enough power to spin tires, you will notice that BOTH tires spin. If you have an abundance of power, you can leave a matching pair of long marks.
Note to drivers in the rain..... The high torque situation above tends to cause tires to slip when making a corner in the rain under power. This is the only drawback I can see about the Torsen.....
My two cents,
