1 - 9 of 9 Posts
AMENDED!!!
This topic keeps popping up now and then and it seems another trend is on the way. Here is what I have found out that might help someone. In addition to the many many articles a few of us on here have written to repair the out of stock OEM units, there are aftermarket parts and even new complete assemblies that will work with a simple modification.
If you are having issues with a weak door lock and unlock issue, you can replace just the motor. You can buy a generic GM one, cut it off the new one and replace the bad one. Will need to plastic weld or seal it well after cutting the case.
These are still available as OEM for $93 on eBay if you Google the part number. Coming from Michigan.
Discussion Starter #4 (Edited)
The SSR OEM is 15115931 and 15115932, I could not find them any anywhere. Maybe you are talking just the replacement actuator that can be removed and not the entire locking assembly? The compete Dormans mentioned above at $50 would do the trick if you can spend 1 minute slightly enlarging one hole.
If you can find the OEMs at that price a link would be nice as I cannot find any.
It is the door lock kit? Not sure what that means but I Googled GM part 15066132 and it came up with various suppliers and price ranges. Could these be interchangeable?
Discussion Starter #7 (Edited)
As mentioned in above post, still researching if the S10s are going to work properly.
I think the motor in mine may be bad as the RH actuator will only UNLOCK but not LOCK? I have checked the voltage and it is the same when hitting the button for either function, but there is absolutely no movement for LOCK.
What si the best way to solve for the long term, as i hate tearing door panel off. LoL
I have rebuilt Door Latch/Lock Modules in stock. Driver and Passenger.
I ask $50.00 exchange, includes Parts, labor, Mailing, send your old one, I send rebuilt one.
I take PayPal.
I have Doorman Door Latch/Lock Modules in stock, have to modified to work on SSR. $175.00
How to Library: https://onedrive.live.com/?id=3EF39D9F5ADCE5E5!853&cid=3EF39D9F5ADCE5E5
1. Dorman and OEM are not the same!
2. Water in detent switch
3. Water ruined motor. I buy motors and reverse polarity to work in our SSR Module
4. Water in lock unlock contact.
5. Rebuilt Door Module
1 - 9 of 9 Posts
