Now that these kits have been installed on many SSRs for a number of years, saving us from the same problem that plauges the other vehicles built on or same chassis (TrailBlazer and Envoy..... we won't talk about the Ascender!), I have heard that the same shift cables are starting to fail at the OTHER end (where attached to the "shifter" in the console)! Has anyone made any connection between the two? In other words, is "strengthening" the transmission end making it more rigid on that end and thus is causing more strain on the "shifter" end, and over time is causing that end to fail??
Should we start a thread where members can report that the "shifter" end of the cable has failed and whether or not they have previously installed this "Shift Cable Kit"? We could then analyze if there may be a "linkage" (sorry couldn't resist!) between the two.
By the way, I have heard that when the "shifter" end of the cable fails, it requires a new OEM shifter cable from GM; it is not a "quick fix" like replacing the nylon grommets on the transmission end. And, of course, opening up the console (without accidentally breaking tabs or scratching the finish) to get to the shifter end is no easy job! And then it needs to be attached to the tranmission end again....
