I'm getting a GARMIN nuvi with a wireless back up camera. Can I pull power for the nuvi off of rear view mirror????
Yes and NOI'm getting a GARMIN nuvi with a wireless back up camera. Can I pull power for the nuvi off of rear view mirror????
Yes and NO
It depends on the current requirement of your garmin. If 1 amp or less probably ok, but if more than that probably NO!
I would still avoid doing this for a couple of reasons.
1. The power wire (pink) for rearview mirror is only a .35mm wire (approx 28awg) the maximum safe current would be about 3 amps. Realize that there is already current flowing to operate the electronics and lights in the mirror. Note: just because it is fused in rear fuse box at IGN E 10 amp fuse. The wire insulation will overheat at a much lower current.
2. 28 AWG wire is very small and hard to splice without creating some voltage drop that could cause potential problems with normal operation from either device.
3. You would have to splice into a harness that does not have much room to work with
4. You would probably need to cut into the garmin wiring harness -- that could effect warranty
5. You have to splice (cut into!) the factory harness -- I always try to avoid this!
My 2 cents NO -- spend the time and run more wire to a better location. Remember to use an in line fuse dedicated for the Garmin unit. I realize some shops might do it but, some shops may do a lot of things I wouldn't do.
Yes and NO
