1 - 13 of 13 Posts
Ms Donna's Driver
04’ Silver and 05’ Sinister
Can’t tell by picture which fender you are showing. The 03-04 hood prop was on drivers side
I use it to attach my front end bra.
I suspect the bra was designed to take advantage of the hole and not the other way around.
I'd guess to align parts during original assembly.
Sounds like a logical use.
Showing the Right Fender. Prop rod is/was on the left and, if I remember correctly, has a surface mount hinge on the fender and the hole is in the hood frame.
Maybe @freezer or another of the design team will check in with an answer.
Installing Accent lights and installing switch in hole along side on fender. Does anyone know what the original purpose of this hole was? Just curious.
:wink2:
While you're sitting back in Tennessee, sipping some good bourbon.......ya got several people stumbling around trying to answer your question about a damn hole.>:)
Yes, as I recall a real bourbon comes from Kentucky. But you guys in Tenn. have some fine stuff too.:smile2:
Discussion Starter #9
/forum/images/SSRFanatic_2016/smilies/tango_face_wink.png
While you're sitting back in Tennessee, sipping some good bourbon.......ya got several people stumbling around trying to answer your question about a damn hole./forum/images/SSRFanatic_2016/smilies/tango_face_devil.png
Yes, as I recall a real bourbon comes from Kentucky. But you guys in Tenn. have some fine stuff too./forum/images/SSRFanatic_2016/smilies/tango_face_smile.png
What are you drinking? It's either Tennessee Whiskey or Good ol home made "Shine".
:wink2:
Right, everyone knows that NOBODY in Tennessee drinks Bourbon (it's against the law isn't it?).
There's a round hole toward the back of the fender, also. My guess would be that those two different holes were used for positioning in the stamping die. I believe it took multiple stamping passes to complete the fender shape.
Reactions: BlueStreak
Weight reduction to help it pass emissions standards.... Yes I am kidding.
With there being a hole in the inner structure to match I would say there was some pin there in the set up jig at the assembly plant most likely to help position the inner structure and fender.
Or like TopSpin said it may have been for positioning when they stamped it.
Or one last thought is that a lot of stamped parts have to be cleaned after they are stamped. They may have been run through a cleaning tank or spray and the holes are what they hung them by. I worked for a fireplace manufacturer and a lot of the fireplace parts were run through this big huge pressure washer booth thing on a trolley system and they had to hang so they got fully cleaned and dried that way.
1 - 13 of 13 Posts
