Hi, Tricky - keep us posted on what you find for wheels. I've been looking for a nostalgic look - very open 5 spoke design, but either the size combination isn't right ie only 18s and 20s, or the bolt pattern doesn't match, or the offsets are wrong. Not many wheels are made to fit the Trailblazer bolt pattern, and the ones that are can't supply wheels that can match the drastically different front and rear offsets.
Check out the Foose website - I've called them a couple of times to see it they have any though of building the Lusso in a combination that would work on the SSR, but no luck so far. Maybe if others call, they would reconsider it. They have it to fit the full size GM bolt pattern, but only in a 20 x 8", and the 19s are for a car. What I found interesting was that they were able to make a 5 spoke wheel look good on a 6 bolt hub. The other design that I'd really like is the Coddington Smoothie II, but no 19s and so far no development in a 6 bolt pattern.
I'm not a big fan of the stock wheel - maybe GM has an optional wheel on the drawing board? - the new Corvette wheel would be a great starting point.
:thumbs
