Automotive lifts come in many types, sizes and capacities. BendPak/Ranger manufactures different capacity portable lifts. One model (BL-7000 SLX) has a 7000 pound capacity. This jack will easily lift an SSR for tire or brake work, oil changes or for detailing. When using this unit to lift an SSR, the optional SUV/truck adapter kit is not required- the standard rubber lift blocks suffice. Attached are two photos of an SSR on one of these lifts, showing it in each of the two stop positions. At the first stop, the distance from the floor to the underside of the running board is 18-1/2 inches. At the higher second stop, the distance to the underside of the running board is 22-1/2 inches. The third photo shows the power supply and handheld control used to raise and lower the lift. The model shown here operates on 120 volts but both 220/240 and 12 volt versions are also available. When not in use the left and right sides of the lift can be stored upright against a wall and the power unit in a box or on a shelf.
Here’s a link for more information:
https://www.quickjack.com/car-lift-systems/bl-7000slx-portable-car-lift.html
