Hi all,
Radiator - I started washing my new toy this morning and I started in the engine compartment. I notice that the large hose laying over the radiator support, under the air cleaner duct, is flat almost the entire length of the straight part that rests on the support. Usually this problem is caused by a bad radiator cap. The only cap I see is on the overflow tank, is there another one somehwere?
I took off the overflow tank cap and it was rather sticky on the threads and seal(from the Dex?) so I cleaned it up and placed it back on. Could this be the trouble or should I take it in for service? No cooling issues that I am aware of but I've only had it a few days.
Radio - Auto level sound. The manual says that if you press the auto vol button you should get 5 readings (off, on, low, med, high) but all I get is "on" and "off" and I don't notice much if any change in volume. Am I missing something or is that another dealer repair item on my list?
Thanks in advance for any assistance,
:seeya
:seeya
