is it hard to change the raditor????/
Actually very straightforward. I had to do it.is it hard to change the raditor????/
As I recall, I didn’t have to support it. I was very careful with it. Getting the condenser off the clip on right/passenger side of the radiator was the tougher one, the driver side was easy. You can break the clips off the radiator, if you aren’t going to re-use it. I might have zipped tied the condenser up for the couple days while I was waiting for the new radiator, but that was it.How did you support the condenser while changing your radiator? I will be replacing my radiator soon and don't want to remove the condenser lines from the AC compressor which would require evacuating and refilling the AC system.
On SSR How to Library, sorta:Yeah, unfortunately I couldn't find Radiator removal/installation on Dictator's How to Library.
Link to the "How to Library"
But thanks to Robert!! He gave some pretty darn inclusive instructions there!! :smile2:
