1 - 11 of 11 Posts
When I give the truck gas, the radio makes static noises. Any tips on why it does and how to stop it?
OEM or aftermarket radio? Aftermarket radio installers sometimes tie grounds from the different components together and/or use the original radio harness ground for the new components. This can cause a ground loop, which can cause static. Try grounding components separately.
Did the static recently start, or has it always been there?
What, if any work has been done to the truck recently (spark plugs, plug wires)?
What does the static sound like...does it change with RPM?
Discussion Starter · #5 ·
Only had the truck a few months so I'm not sure.
Does it when you hit the gas and the truck is under a load.
Genuinely SSR Obsessed
Personally speaking, I see you have an LS2 (an '05) so I would just turn off the stinkin' stereo and listen to that "sweet underhood sound".
:laugh: :laugh: :thumbs
David :black:
OK, here’s a few things to check that can cause RF noise; non-resistor spark plugs, non-resistor spark plug wires, bad alternator, bad radio ground, bad radio antenna connection.
If all else fails, run it by a car radio/stereo shop for a listen.
Ex SoCal Nut
do you know if the alternator was changed ? were you next to a Ford when this happens ? Dr Who has some good suggestions. Also check antenna is plugged in all the way if only in radio mode.
1 - 11 of 11 Posts
