As many of you know, I have had my fair share of trouble on #856, 03 SSR, especially with the roof. My guy John at Priority has been a virtual saint and has the patience of Jobe. He recently installed my new hinges for the top and it does operate, however, there is still one very big problem. The tonneau cover opens higher on the passenger side and lower on the driver side. In other words, the tonneau is lifting diagonally and there are now scratches and rub marks of significant size on the passenger side as a result. I was looking at my GM Service manuals (which I should have taken with me today but did not) and they show the Roof Door Module (RDM) controls the amount of pressure that goes to the cylinder to move the tonneau in whatever direction it should go. It seems to me from what I have read in the tech. Helms service manual, that the RDM simply needs to be reset or else there is a very small leak somewhere in the system. I plan on dropping off my manuals for John to look through for a few days and try to identify the problem and then letting him have a shot at adjusting the top again to get her going right. Interestingly, after 3 or 4 roof cycles, she goes up evenly, indicating that pressure is built up after a few cycles. Any of you guys in the factory that may be reading this, or someone that is in the know mecanically with hydraulic systems, we sure would appreciate some feedback to resolve my roof problem. The helms manual sure has an awful lot of pages just on the roof!!!! :confused
also, John looked everywhere for a leak and none could be found. I have yet to find the master cylinder locks for the hydraulics in the manual. They are apparently in the rear wheel fender walls and require some disassembly of the vehicle to access them. Perhaps one of them is leaking?
