I don't know if everyone's shifter is as far to the right as mine, close on the bezel in the reverse gate and requires a little reach for 5th & 6th. That is the way it was with the original shifter, but neither my Z28 nor my GTO, both six speeds have that issue. I personally would like my shifter to be closer to me(a bit left) and I should have & could have made it so as Topspin kindly sent me a shift lever that he had shortened and I set it up with a 16x1.5mm threaded termination at the top so I could screw on a Hurst SS shifter ball. Ended up about 1/2 inch lower(shorter overall) than stock, love that, but I coulda angled it to the left a bit at the same time. Bigger ball makes R,5th and 6th a bit more accessible, but as Topspin Quotes "Strive for perfection in everything". I think I would like yours.@tuckerred1948
Still happy with the trans, as @Topspin said, shifter is tight to the left, just clears the bezel. It is different but not bad, just “closer to me”. The gearing feels like stock to me, I think i have 2.66 first, the rest I don’t know. I have a stock 3.73(?) rear gear in it now. I would like to do 4.56 soon.
Ken, you are more than welcome to crawl around and look anytime!
On a side note I wasn’t notified with the @ symbol ... but I keep up with most of the topics.
dna
Are these for auto or 6 speed?Just sayin', I have a set of 4.56 gears for sale cheap if anyone wants to try them out. I used them on Ilsa for awhile, then decided to go to 4.10's for a better high end on the strip. Shipping is around $30, so I'd ship them for $100 total.
Ummm... you're not really go spend that much on a set of gears are you? That's over two times the going rate for a set of OEM gears.View attachment 589294 With posi
Achias--I thank Wizz was talking about GB92270's post # 218 $1,039.95??? sorry for butting in.Really? I spent a lot more than that on them.
I'm really hesitant to stick my nose in here, but I'm just trying to keep everyone here happy/informed. It's a really bad idea to install used gears in a different housing. In fact, any reputable shop wouldn't attempt to do the installation. To re-install that gear set in your housing could be done, as long as the original pinion depth shim was retained. It's best to just write that gear set off!Just sayin', I have a set of 4.56 gears for sale cheap if anyone wants to try them out. I used them on Ilsa for awhile, then decided to go to 4.10's for a better high end on the strip. Shipping is around $30, so I'd ship them for $100 total.
Ah... So you just acquired your SSR and after SEMA it will be sold? Is that what you are saying?I was showing part # , not price, the price was changed as it was out of stock , typical ebay sellers
Iam a ebay seller also
I mfg tundra silicone cup holders and all the coolant hoses for the toy's
4.11 for me , I hope to have this truck for seam, after that it will be sold as I have a Rivian on order
