Yes, I have them in stock but go to Ebay, it's V/W actuator.Does any one have a spare Rear Cargo Lid/Lamp Relay Module?
DicktatorDoes any one have a spare Rear Cargo Lid/Lamp Relay Module?
Sorry, I miss understood what you needed.First - remove fuse #40 in the Rear Fuse Box (10 Amp Fuse in an 05 "R").
The fuse does not blow when the circuit burns.
PM your e-mail address & phone number to me, so we can communicate completely.
I have fixed many burnt cargo bed lights.
I need photo's of the 3 wire connector and the printed circuit board.
Note: I do not know of any factory replacement PC Board or 3 wire connector.
Mike put me in line for one too. Mine was burned up when I got the truck. I removes the connector, relay board and hardwired a switch in at the light. Would like to restore it back to OEM if you are successful with the PC board sourcing. You may run into the same issue I am having with the mud flaps though, the price may be out of line because of the low volume. They may want a minimum run that exceeds what you can sell. Good luck!I have successfully sourced the cable connector, pc board connector and the relay, but have not yet gotten the PC boards built. I just have to find someone in Phoenix that will manufacture the PC boards for me.
Please send an email to me at [email protected] I’ll contact you when I have a completed unit to send you.......
Regards,
