I noticed my rear window defroster is not working and found that the copper traces near the wiring connection points have failed to an open state. The open points are readily visible and verified by continuity check with ohmmeter. I could understand failure point(s) at random locations but the multiple open points are at the supply cable connection points suggesting some contributor to failure.
Just wondering if anyone has tried to repair such via jumper or such. Very wary of applying heat enough to melt solder to a small section of the window due to fear of glass stress and failure.
