I put the rear eibachs on the truck tonight, that I got from Topspin. The truck sits pretty level now. I also cut up my running board brackets and moved them down and in. What a difference! I jacked in two places. I actually jacked on the trailer hitch underneath. That hitch is probably the heaviest thing under there. I lifted it way up that way. But had to finish by raising by the differential, because I ran out of wood shims to get it high enough. lowered the rear 1.5 inches. Not sure if I am going to install the front or not? If the rear settles in a little more, I will do the fronts I think. I did not cut the bumpstop. Was not exactly sure what eibach says to trim off? Anybody know the measurement on that? Next project....... retractable hidaway front plate. Thanks to everyone for the help and advise on the spring job! D:grin2:
