Here is the info on the 1SA mirror upgrade. The installation is not to difficult, but note:
* You will be removing the panels above the mirror, sunvisor, driver post cover.
* It will necessary to find an ignition power source.(fuse box behind pass. seat)
* Run temperature sensor wires to front of radiator.
* Solder wires to relay.(heat sink recommended)
