I just finished installing a new inside mirror in my 1SA SSR. The new mirror has:
**Autodimming
**Map Lights
**Compass
**Outside Temperature
The Mirror is made by Magna-Donnelly, the same company that makes a lot of the OEM mirrors for GM. The display is the same blue as the DIC. It puts the display just below the mirror and does not block the viewing area. It is nice, as you are usually checking your mirror on a regular basis, so a check on the temp/compass is easy. You won't have to search under your dash.
The installation was a challenge because the SSR has a different electrical setup, similar to the Corvette. I was the test case. I have to thank John H. at Maga-Donnelly for the specifications on the mirror and relay detail for the Map lights.
I have posted some pictures and will have some instructions and schematics soon for those who are interested.
Sorry guys this is for the 1SA only. I think the 1SB will require that Centrex brand mirror with the display in the mirror, like the Silverado pickups.
