1 - 9 of 9 Posts
If you are good with the Search feature, which I am not!, it seems some one made them out of washers! Ground flats on 2 sides and Taped the Hole.
Yup, I Tried that trick. It can be done and I was able to do a couple to complete my bag hook up. Once you trim down a big washer to fit the side rails, then you (kinda) need to put a slight (bend)in the damn thing.........(after) having epoxied a nut to it .
You're likely better off getting with the program and having Simple Engineering send you the parts.:frown2:
1 - 9 of 9 Posts
