Mikepowell: I don't know if this can PRACTICALLY be done outside a facotry or not (someone smarter than me needs to answer that one), BUT if it can, the trick mod would be to change 2nd gear ratio from the stock 1.62 to 1.80 or thereabouts, as that would not hurt total 1/4 mile time, but would improve the 0 to 60 mph by about 1/4 second, per my computer modeling software.
The way this happens is that the large "gap" between 1st and 2nd gear is made smaller, so you no longer would fall off the power curve right after the shift into 2nd.
You do NOT want to instead move 1st towards a smaller number (stock is 3.06 ratio), unless you have a supercharger or high stall torque converter. If you have either of those mods, that might be a better idea. But, with a stock engine, 1st gear will be too "tall".
