ykp53 said:
how do you reprogram the windows?
I found this in another thread: Hope it helps:
"The computer has forgotten the window positions for top and bottom of travel and needs to be reprogrammed. This you can do for your self. The 04 owners manual pg 2-10 tells how.
From the manual:
Programming the Power Windows
If the battery on your vehicle has been recharged,
disconnected, or is not working properly, you will need
to reprogram the power windows for them to work
properly. Before reprogramming, you will need to replace
or recharge your vehicle’s battery.
To program the windows, follow these steps:
1. With the ignition in ACCESSORY or RUN, close
the doors.
2. Fully lower the windows using the driver’s power
window switches. Then raise the windows
completely.
The windows are now programmed.
It didn't say in the owners manual, but I remember reading elsewhere that you should not use the express down to lower the window. Hold the down button down until the window bottoms and for a couple seconds longer. When raising the window, do the same hold for a couple of seconds after it tops out."
