1 - 12 of 12 Posts
There have been several threads about re-doing running boards so I thought I'd throw what I did into the mix. I had the rubber tread removed and had them sprayed with rhino bed lining spray. The truck won't win a concours contest, and some may hate the look, but I gotta say, I love the look and they are tough as nails. Oh, and it cost about about $100 to do the whole job.
There is a place here that does LINEX in the color of your vehicle. I like the way yours looks very much in the black. Mine are yellow and always end up with a few black heal marks on them even when careful your feet seem to drag across them a little. Looks good.
LiINEX brag is a different application pressure so theirs always stays shinny and they can do black or mach your vehicle color. Have seen a few pickups around with the rocker panels done or the lower body panels done in color and it looks good. I have Rhino lining in work truck bed and I noticed it gets sort of a silvery white after awhile. If you take dawn dish soap and a brush it cleans that film right off back to black. LINEX says theirs does not do that. Don't know if that is true or not but I do like the way it looks on yours. By the way did you have your stone guards carbon fiber dipped? Was thinking of having my rear wing dipped to look like carbon fiber. What do you think?
2006 Pac Blue FPR Auto
My first thought was how it would look if you also used the Rhino liner material on the stone guards to match the running boards.
Discussion Starter · #9 ·
Dave, I might do that at some point. There's an SSR here in Albuquerque that has the rock guards sprayed with the stuff. He also has the front sprayed like a bra. The rock guards are fine but the front is too much in my opinion.
I don't care for it but on a positive note, no stone chips.
Augie... you got me thinking. I went back and looked at the stuff they sprayed on my boards. It is Line-X!!
You should be good to go. Like the look. All the new Corvettes, Cadillac's, etc. Have the carbon fiber pieces on them and I really like that look. I was thinking, front spoiler/splitter, rear wing and maybe a few other parts. There is a guy here that does the Carbon Fiber dip and then clear coats it and it looks awesome.
Discussion Starter · #12 ·
A little carbon fiber bling would look good on your yellow ride. An I've heard the dip process is a good way to go. :smile2:
1 - 12 of 12 Posts
