1 - 15 of 15 Posts
Help, Our 2006 SSR right side window moves down when opening the door, but it goes back up before the door can be closed. The timing is off. Is there a fix for this?
EDIT Engine must be running.
More then likely a problem in the door latch assembly
There is a small switch in there telling the module that the door has been closed when it really hasn't been and the module responds by rolling the window up.
If you are in the drivers seat with door closed and key in the on position and engine RUNNING after all the normal opening displays on instrument cluster, watch the driver information center on the dash as you open the passenger (right) side door and then leave it open until window moves back up.
I would bet it will indicate passenger door open as the door is opened and then near the same time the window rolls up - the passenger door open display disappears.
Realize it could be wiring but the common failure is one of the switches in the latch assembly. I can provide you with wiring diagrams and testing information if you have that interest or capability.
The problem is the latches are no longer available but I believe there are a couple of people on this site that can rebuild them. I am sure they will reply soon
Discussion Starter #4
If you are in the drivers seat with door closed and key in the on position and engine off, after all the normal opening displays on instrument cluster, watch the driver information center on the dash as you open the passenger (right) side door and then leave it open until window moves back up.
Realize it could be siring but the common failure is one of the switches in the latch assembly. I can provide you with wiring diagrams and testing information if you have that interest or capability.
Thanks I will check that out, Tim
@Tim And Melinda I failed to mention that the results I described may not show up on the DIC if the window rolls back up TOO soon after door is open. It takes time for the display to update. Try watching the DIC while opening and closing the drivers door to get an idea of what would occur and how long it takes to recognize AND display door is opened and closed.
I also edited the first post after having an opportunity to try on my own. The engine MUST be running for the DIC to warn of an open door.
SORRY, I never really tried to determine if the engine had to be running or not. I just got home and I tried it. No warning for either door engine off, warning for either door is displayed if engine is running.
I learned a new thing. ?
Have you tried resetting the windows like it says in the owners manual? It may fix your problem. Just a guess.
Here is a write up I did some time ago to show what the problem is and how to fix it if you are so inclined. There is a very very small chance it could be as Autoprof noted, a wiring issue, 99% of the time it is moisture that corrodes the internals and causes the signal not to go when and where it should with the position of the handle.
f you click the link below it will include pictures and more information.
You may be able to TEMPORARILY fix the issue by spraying with dry lube into the door latch area and from the top, down into the door lock. This has worked for me in the past, but again, it is not a permanent fix.
Door Latch/Lock Modules are getting OLD! And they don't make them anymore.
Dorman makes one that needs to be modified to work on SSR but only LEFT Drivers side, NO RIGHT side.
I have repaired SSR Door Latch/Lock Modules in stock, Right and Left.
I do exchange: Send me your bad unit, I send repaired unit back same day. Include $50 for parts/labor/postage.
I take PayPal:
Removal instructions on my SSR HOW TO LIBRARY: Look up DOOR LATCH LOCK MODULE
That said, you could have broken wire in harness. I DID!
Discussion Starter #14
Thanks for all your help. The cleaner did fix it for now. I will have to remove the handle and have it rebuild this winter after we park the car. Thanks again.
Tim
1 - 15 of 15 Posts
