1 - 2 of 2 Posts
what is the backset, offset and other info for our rims? does anyone else know if another chevy rim will fit? i dont care if the back is not the right width. im planing to use it as a spare only.
From the research I have done, the front is +35 mm with a 5 1/4 inch backspace. The rear is +15 mm with a 5 1/2 inch backspace. The +35 mm and the +15 mm is similiar to measuring the off set on a front wheel drive vehicle.
A trailblazer has the same bolt pattern. It is 6 x 5 inch or 6 x 127 mm (both are the same according to the wheel companies.) Hopes this helps.
1 - 2 of 2 Posts
