Window Rubber
I have my SSR in right now for this same condition...dealer already tried heat gun
to reform the moulding, worked ok for about 1 week, then folded under again...
I knew this was possible but thought I'd rather do this then pull the top apart if
did not have to. Now we are replacing the moulding, also adjusting both windows in slightly. Man, I hated seeing it apart like that but since I work at the dealership I can see what is going on...Just find a dealer you trust and ask if they have a dedicated trim tech that is trained on the SSR folding top assmebly. Since is apart am adding some sound deadner above headliner while is apart, should make some difference in noise level. :thumbs
