1 - 10 of 10 Posts
Been working about a year with more than one shop to come up with replacement for the OEM Roof Pump Reservoir.
Here are some pictures and I finally have the one that will work. OEM pump reservoir has been discontinued.
There is Pressure inside reservoir so it is not as simple as it looks, MUST seal, system self purging.
Also need inert material that is pliable and strong.
I will be adding Reservoir to HOW to LIBRARY for removal and install.
1. Picture of pump and OEM Reservoir
2. What we usually find in OEM Reservoir.
3. OEM material softens form heat, dimples and leaks.
4. OEM "Brittle" plastic cracks from age, heat and pressure.
5. NEW replacement Reservoir, longer, stronger, more pliable material. Sent with NEW Clamp and "O" ring.
ONE OWNER !!!!
Looks great thanks for solving another problem for us !!!!!!!!!!!:grin2:
Discussion Starter · #6 ·
Thanks! Here are more pictures.
1. Have five in stock, $120.00 includes shipping, PayPal [email protected]
2. Sliding on pump.
3. Transfer Brass plug from YOUR OEM to New Reservoir.
4. Mounted on Pump.
5. Comes with NEW 'O" ring.
2. Sliding on pump.
4. Mounted on Pump.
Mr. Dicktator, Those look great. If you would, put one to the side for me and we will stop by in a couple weeks when Deb is off work on Saturday to pick it up and save you shipping. If that is OK.
Thanks, sillypuddy and Old Yella :yellow:
Discussion Starter · #8 ·
OK Ed, I will set one aside for you.
Had nine a few days ago.
1 - 10 of 10 Posts
