1 - 5 of 5 Posts
2006 SSR
Is there a known problem with the roof rubbing on something in the down position? I have a rub mark on the passenger side roof pillar, L shaped , & it looks like it happened when the roof was down .
I think you're safe in assuming it happens with the roof down. I mean, if it's up, what could it come in contact with? Did you look what happens (contact) when you drop the top? Post pics of the rub marks. Maybe someone will shine some light.
The rub marks on your roof are from the split loom tubing on your hydraulic lines to the tonneau cover. You will see the service loop just below the hinge.
The solution is to massage the split loom a bit and move the tie wraps on the bundle a little, so the service loop does not go straight toward the top when the tonneau goes closed.
Regards,
2006 SSR
Discussion Starter · #5 ·
Regards,
Thank you I will look there .
1 - 5 of 5 Posts
