Double sided tape for the rock guards as I've had mine off and painted.Question about the running board rubber, are they just glued on? also,
The rock guard on the front of the rear fenders, are they just glued on too?
Thanks,
I agree with you 100%...it takes work to clean them...and maintenance is the key...I took the rubber off when I had my boards painted to match my SSR...put but rubber back on...magic eraser years ago removed the white residue build up.Good LuckI used Mother's Heavy Duty Back to Black and a lot of elbow grease. I was extremely pleased with the results. After a good cleaning then occasional maintenance cleaning should do the trick.
Thank You, What about the running boards? Anybody?Double sided tape for the rock guards as I've had mine off and painted.
My SSR is also silver and looks just like yours does, I was interested in seeing how you have "dressed" your SSR.As another way to deal with it... I took the rubber off and threw it away. Then I had them coated with Line-X bed coating. Or you can paint them body color.
The rock guards are held on by strong double sided tape around the edges and one screw on the bottom. It takes a little time to get them off. You'll want to use new adhesive tape when you re-install. Mine were not painted but rather wrapped with 3M carbon fiber vehicle wrap vinyl. And don't worry about copying the idea. I certainly am not the first person to modify the rock guards.My SSR is also silver and looks just like yours does, I was interested in seeing how you have "dressed" your SSR.
I really like the rear fender rock guard painted black. And since my SSR lives in Michigan, it should be OK to copy your design and paint mine black also. How is that rock guard attached to the rear fender? Are they difficult to remove? And how about re-attachment?
Street Rod Andy
There have been other threads on this subject which have included the use of paint on bed liners as a solution to the question of what to do with the rubber. I have found this to be a viable solution if it is applied carefully on properly prepared running boards. I have also seen it fail miserably when not properly installed.These are all great ideas, and I thank you all for responding with these ideas. There may be more ideas still to come. But I wanted to acknowledge the time that you took to offer up some great suggestions. Ultimately, I like the idea of painting the running boards, and not having to worry about the old rubber discoloring.
