The windows screensaver called "pipes" has a setting to allow you select a texture to be painted on each pipe as it is generated.
The picks are Desktop>rt-click>select properties>tab screensaver> dropdown to 3d pipes > settings> choose texture.
Any bitmap picture of the types bmp, jpg, tga, png can be selected.
Download the one I've attached, or make one of your own. The picuture needs to be tiled otherwise the image is wrapped all around the pipe and most is not visible.
