Skip shift, more correctly called "CAGS", applies ONLY to manual transmissions. There is no comparable feature on automatics (thank goodness).
Furthermore, although the Corvettes have CAGS, I have not researched to see if the 6-speed SSRs have it. They might or might not.
What CAGS does on a 6-speed is it places a mechanical barrier into the shift pattern, that forces your hand to move the shift lever NOT from 1st to 2nd, but rather from 1st to 4th gear, when you shift. This is to further improve (rather foolishly) the mpg achieved on the EPA-mandated mileage test for vehicle certification.
CAGS only works like this at LOW throttle settings. If you apply more than a specified amount of throttle, the PCM sends a signal that retracts the mechanical barrier and allows a 1st to 2nd shift.
IF the 6-speed SSRs have CAGS, it can be defeated one of two ways:
1. Installing an aftermarket part into the wiring harness that leads into the transmission. This aftermarket part generates a signal that keeps the mechanical barrier retracted. The part is inexpensive - about $25 or $30 as I recall from a few years back, but you have to know where to install it, and a lift sure makes it easier, so you'll probably pay your local hot rod shop (NOT your Chevy dealer!) to install it. It takes all of 5 minutes plus the lift up and lift down time.
2. CAGS is defeated even easier IF you have access to the PCM programming, as it is a simple enable/disable field in the PCM software. The catch here is that the CAN-based software in the 05 SSR has not yet been cracked and released to aftermarket suppliers, so right now you simply don't have this capability yet! But when the software IS released, this is the better way to go, as it is electronic rather than mechanical, and if done along with other useful programming changes ( :reddevil ), it costs nothing extra.
I've always wondered why GM saddled the manual transmissions, which already give better fuel mileage than the automatics, with this impractical feature. JUST TRY driving with CAGS enabled - it'll drive you crazy and break your high-rpm engine's back. In my opnion, it's abusive to the engine.
