Incorrect Post #3
I was incorrect in post #3. It is the LM486 that is needed in an SSR if you have LED lights or LEDs mixed with regular bulb. I have corrected post #3. This is a post from Dictator about the correct flasher.
"LM486 Flasher/LED lights
LM486 IS the Module Flasher to use on ALL SSR's any year.
Model TRIDON LM486 by NOVITA'
I have updated Florida Suppliers List.
I contacted Novita and not only spoke with engineering but they sent the attached Email.
Dicktator,
We reviewed the issue in detail and since we are the OEM manufacturer of these modules, we found that a different OEM part number was listed for the SSR and the OEM design was different as well. We then quickly introduced the LM486 to correct the cruise control issue entirely.
The proper part that should be used in your SSR vehicle is the LM486 which is a different design than the LM487.
If I recall correctly, there was also an issue with a NAPA branded LM487 that was considered to be a Novita Lighting Control Module. Novita does not currently sell any flashers or Lighting Control Modules to NAPA so those products are made by an overseas manufacturer that does not supply OEM.
I hope that answers your questions and good luck with your seminars. Thanks.
Joseph LaCourt
Product Manager
Novita’ Techologies.
This should clear up the LM487/LM486 controversy.
President Florida Chapter
