Guest
·Got new ssr friday ready for more power. It is a 04 auto trans 5.3 pooch. LS6 crate motor will take care of that problem but what torque converter? blown for sure and 3:73 should wake this thing up.
GMfixer -- There is alot of information in the technical discussion forum --- believe me most of the areas have or will be addressed in fine detail --just participate and you will get info. I'm curious as why you would go to the trouble of installing a LS6 when you could install a Magnacharger easier and for slightly less coin and make more power. The SSR comes with a 3:73 rear gear and the first item to install would be at least a 4:56 or higher numbered gear. Just my $.02 worth! Good luck with your ride!!!GMfixer said:Got new ssr friday ready for more power. It is a 04 auto trans 5.3 pooch. LS6 crate motor will take care of that problem but what torque converter? blown for sure and 3:73 should wake this thing up.
