My speedometer and other gauges are not working properly. I'm afraid to take ULTRVLT to local dealer. The last time they didn't even know what an SSR was. Any recommendations for a mechanic in the Denver area? (Pic from Sante Fe rallly)
Not that unusual... but agreed, I wouldn't take it to a dealer. It sounds like one or more of the stepper motors in your gauge cluster are failing. It's likely a fairly easy fix but before going any further, go ahead and post as many details as you can. For instance, when you start it up do all of the gauges in the dash sweep all the way to the end, back again and then begin working normally? If not, which ones are not working correctly? Is there anything else not working normally?My speedometer and other gauges are not working properly. I'm afraid to take ULTRVLT to local dealer. The last time they didn't even know what an SSR was. Any recommendations for a mechanic in the Denver area? (Pic from Sante Fe rallly) View attachment 627344
I also used dragon2u. It was a bit time consuming to remove but it can be done. Great instructions on the forum.Not that unusual... but agreed, I wouldn't take it to a dealer. It sounds like one or more of the stepper motors in your gauge cluster are failing. It's likely a fairly easy fix but before going any further, go ahead and post as many details as you can. For instance, when you start it up do all of the gauges in the dash sweep all the way to the end, back again and then begin working normally? If not, which ones are not working correctly? Is there anything else not working normally?
There are a number of folks here that can either walk you through the repair or at minimum give you the info needed to have someone else do it.
In the meantime, have a look at this DIY library. Look for "Cluster Removal":
Repair Procedures and Solutions – Simple Engineering, LLC
Nice photo by the way!
As soon as you post additional details folks like @Dicktator, @Autoprof and others will be along to help you get things good as new.
Oh no!! A wench with a wrench. I bought the fan from Simple Engineering when I first bought my SSR. I haven't had to do anything else since then. I find taking off the dashboard a bit daunting and I'm afraid I'll get started and not have the right screwdriver. Oh well, its winter and there is snow on the roads, so perhaps I'll give it a go. If not I'll just keep driving at whatever speed traffic allows!Not that unusual... but agreed, I wouldn't take it to a dealer. It sounds like one or more of the stepper motors in your gauge cluster are failing. It's likely a fairly easy fix but before going any further, go ahead and post as many details as you can. For instance, when you start it up do all of the gauges in the dash sweep all the way to the end, back again and then begin working normally? If not, which ones are not working correctly? Is there anything else not working normally?
So I didn't see any additional details. Are you sure it's the stepper motor(s) that needs replacing? If so, it's not that difficult to pull the dash and the instrument cluster.Oh no!! A wench with a wrench. I bought the fan from Simple Engineering when I first bought my SSR. I haven't had to do anything else since then. I find taking off the dashboard a bit daunting and I'm afraid I'll get started and not have the right screwdriver. Oh well, its winter and there is snow on the roads, so perhaps I'll give it a go. If not I'll just keep driving at whatever speed traffic allows!
