First let me say I lover my ride. I have found nothing basically wrong with the machine.
On the Air Conditioning issue.
I was able to inspect four 05 SSR’s including mine, for the problem with the compressor clutch cutting in and out on a 10 to 12 second interval.
10 seconds on and about 10 seconds off on all four 05 SSR’s .
On mine I was told everything was fine and rapid clutch operation was to
provide better fuel mileage. My clutch has been on and off over 70,000
times so far. BAD ANSWER!
The next dealer conceded the clutch operation was not correct. After talking
to the factory they were allowed to replace the expansion valve.
Replacement of the expansion valve provided a ‘clutch on’ of about 15 fold;
now the clutch would be engaged for about 150 seconds and off for about
30 seconds on full fan, a hot day, and windows down. Still unacceptable!
The expansion valve is an interesting device. It is used to moderate
the spray of the cooling liquid with a variable orifice in the expansion coil.
Its operation is complex as it maintains a predetermined temperature
in the expansion coil located under the dash.
A safety device also located in the expansion coil under the dash is something referred to as a “cycle switch”. It is not a switch! IT IS A THERMISTOR!
A thermistor is a resistor that has a related positive or negative going
resistance due to temperature. A current is fed to the thermistor and the variation of this current determines when an open collector switch in the on- board-computer turns the clutch on and off. My expansion coil never freezes.
I have never found water dripping from the outlet water tube.
All thermistors are not created equal. Thermistors that have 1% tolerances are
expensive and we all know GM is in the business of cost cutting. The variation in tolerances of this device explains why some of our SSR’s report no problems
with the A/C. They got lucky!
T H E F I X
The fix is in proper programming of the on-board-computer to compensate
for variations in the thermistor tolerances allowing this device to provide freeze
protection without interrupting the normal operation of the A/C system.
Changing out the thermistor is difficult as the whole dash must be deconstructed and then a new thermistor will not guarantee a fix. The programming must be allowed to correct for variations in characteristics of the thermistor and its placement in the expansion core.
This is not rocket science. Why did GM give dealers this problem when a factory ‘twek’ in programming compensates for the two variables of the thermistor; tolerances and location? What kind of crap is this? A high end vehicle with this problem is unacceptable!
As for the future of GM all 150 of my friends and maybe their friends, know about the problems with my SSR. They also know it will not be corrected for
whatever reason!
T H E F I X
whatever reason!
