A number of people have been speculating as to whether to observe the 30 psi tire pressure recommendation from GM, or to go higher.
Based on some testing I have done, and in the absence of more detailed data, I would have to say Do NOT go higher.
I have been running 33 psi, using first norma air, then Nittogen, and then air again, and found the following:
1. Front tire tread wear is uniform across the width of the tire (good), but
2. Rear tire tread wear is NOT uniform. MUCH more tread wear across the central part of the tread than at the edges - like almost double the wear. This indicates pressure was too high.
30 psi set with AIR as opposed to Nitrogen allows for the fact that air pressure expands aggressively with higher temperature, so the operating pressure is obviously much higher than 30 psi. NITROGEN pressure varies much less with temperature, so will likely be somewhat lower than AIR pressure once operating temperature is reched, if both start at the same pressure.
My limited testing is not enought o draw grand conclusions, but I think it's safe to say that 33 psi is too high.
