1 - 20 of 114 Posts
RetroCarGuy530
Hello everyone. This is Robert Baller. I've created a social medial company (RetroCarGuy530, LLC) that creates videos about a variety of car topics.
One of the main topics I'll be covering is the Chevy SSR. My current 2004 Chevy SSR is my fourth one. :grin2:
I've created a few threads on this site with links to the videos related to the SSR. I thought I would create this thread that will have links to the other site threads to make it easier for a person to find the various threads on this site and the videos on my YouTube channel.
I'll update this post with a link to each new thread I create on this site that has a new Chevy SSR related video.
I hope these videos provide my fellow Chevy SSR owners with information that makes owning your Chevy SSR a little bit easier.
I only ask that if you find the videos helpful to you, please subscribe to my RetroCarGuy530 YouTube channel (see the link in this post). I need to get at least 1000 subscribers on my YouTube channel before I have the potential to make anything from the time/effort I put into creating these videos. Subscribing to my YouTube channel does require that you have some sort of Google issued user account (gmail, google, youtube).
Here's a link that will take you to YouTube and present a list of the Chevy SSR videos that I've put together:
YouTube: RetroCarGuy530 - Chevy SSR Video Playlist
This link will take you to my YouTube channel and ask whether you want to subscribe to the channel:
YouTube: Subscribe to RetoroCarGuy530 LLC Channel
Thanks!
2003/2004 Chevy SSR Fuel Filter Replacement
GM / Chevy SSR Key FOB Programming | Autel MaxiSys MS906
SSR SE-MFK-1 Radiator Cooling Fan - Installation
Chevy SSR Review on YouTube
Replace Rear Sway Bar End Links Video
3rd Brake Light Pulser
Access Turn Signal Switch / Ignition Switch
Ignition Switch Replacement Video
Dash Camera - VIOFO A119S V2
Autel MaxiCheck Pro Handheld Scanner Review - Chevy SSR ABS Automated Bleed
SSR Tech Session - 8/25/2018 - San Jose, CA
HVAC Blend Door Calibration
Introduction to Simple Engineering
LST Deck (Cargo Cover) Struts - Installation Steps
LST 2003/2004 Hood Lift Kit - Installation
SSR Front Fascia Stabilizer Kit - Installation
SSR Lower Radiator Support - Installation
SSR Anti-Lock Brake Module Heat Shield - Installation
SSR Replacement Air Dam - Installation
SSR Front Brake Pads and Rotors - Installation
SSR 4-bolt Rear Crossmember - Installation
SSR Front Frame Stiffening Plate - Installation
SSR Retractable Hardtop Maintenance and Adjustment Tips
SSR Side Window Re-Indexing / Programming the Power Windows
Rear Cargo Area - Water Leak Prevention Tips
Autel MaxiCheck Pro - Chevy SSR Smog Check Readiness
VIOFO A119 Pro Dash Cam - Unboxing / Firmware Upgrade
Race Ramps - RR-XT-2 67" Ramps / RR-EX-14 67" Xtender
2019 CA Exhaust Noise Law Change | CA AB 1824 | Q&A
Bilstein Front Shocks - Installation
SSR Front Wheel Hub - Installation
SSR - Crankshaft Position Sensor Install
Car Cover Removal / Installation - Chevy SSR
YouTube: How To - Add a Fuse Tap in Your Vehicle
YouTube: How To - Change Low-Beam Bulb - Chevy SSR
YouTube: How To - Chevy SSR Door Panel Removal / Install
YouTube: Chevy SSR - Random Window Indexing Fix
Cacagoo Wireless TPMS - Tire Pressure Monitoring System - Unboxing / Review
YouTube: How To: Chevy SSR Wheel Cap Removal / Installation
YouTube: How To: Replace Spark Plugs & Wires - Chevy SSR 5.3L LM4
YouTube: 2003-2006 Chevy SSR - Power Steering Pump Replacement
YouTube: 2003-2006 Chevy SSR - Cooling System Refresh
YouTube: 2003-2006 Chevy SSR - Simple Engineering, LLC - Heater Core Hoses
YouTube: Replace Fuel Pressure Regulator - Late 1990s to mid 2000s GM Return Style Fuel Injection Systems
YouTube: 2003-2004 Chevy SSR - Replace Fuel Pump
YouTube: Chevy SSR / Trailblazer / GMC Envoy - Repair Leaking Fuel Tank Inlet Check Valve
YouTube: 2003-2004 Chevy SSR - Replace Intake Manifold Gaskets / Fuel Injectors
YouTube: Chevy SSR - Replace Glovebox Door Handle
YouTube: Chevy SSR - Oil Change Quick Tip
YouTube: How To: Contact Retention Test - Chevy SSR Main Cooling Fan
YouTube: GM Automatic Transmission Shift Cable Repair Kit
YouTube: Chevy SSR - Exterior Door Handle Common Problems
YouTube: Chevy SSR - Door Latch Overview
RetroCarGuy530
Discussion Starter #7
I added two links to the first post.
One that takes you directly to my YouTube channel Chevy SSR video playlist which contains all of my SSR related videos.
The second one is a link that will take you to my YouTube channel and prompt you whether you want to subscribe to my YouTube channel.
Please subscribe to shiftz33's YouTube channel - he's only 811 away from getting some benefit from doing all this work.
Reactions: shiftz33
RetroCarGuy530
Discussion Starter #10
I'd like to thank everyone that has subscribed to my YouTube channel. I'm at 198 subscribers as of this morning!
The viewer metrics are getting a tiny bit better:
Last 7 Days:
Subscribed Viewers: 9.2%
Not Subscribed Viewers: 90.8%
All of my SSR specific content will only be on my YouTube channel and there will never be any cost to view the videos.
I have additional videos on Instagram TV channel (yes there is such a thing) and my company's Facebook page, but those also have a version of the video on my YouTube channel.
I'll only "ask" this one last time, because I don't want to be "that guy" that keeps bugging everyone with unwanted requests.
If you find SSR videos helpful, please consider subscribing to my YouTube channel and follow me on Instagram. It doesn't cost anything other than the time to click on the link to subscribe to my channel (see link in the first post of thread).
I'll be transitioning away from my 38+ years of IT / data center operations / software programming / IoT (Internet of Things) when I get laid off from my current job around May 2019.
I'll be dedicating more time and resources to my new company and videos. I have plans to attend 2019 SEMA as well.
I'm hoping to turn 2019 into a great year for my family, learn a bunch of new things and hopefully give everyone here some video content they find useful.
Thanks again!
-- Robert
RetroCarGuy530
Discussion Starter #12
Thanks for the additional subscribers
I've had some success the past 9 days getting some new subscribers for my YouTube channel. I've gained 21 subscribers for a total of 219 as of this morning.
My "not subscribed vs. subscribed" ratio is still about the same 93% "not subscribed" vs 7% subscribed over the past 7 days.
Subscribing to my channel does require that you have some sort of Google issued user account (gmail, google, youtube). I understand that some users do not want to get a user account just to subscribe to my channel.
Making some progress!
Robert, since this is so important to support your efforts, it might be helpful if we had step by step instructions on how to get this set up like you need us to do. Some of us may not be as computer savvy as we would like (me included) ,and we want to make sure that we support your efforts as much as possible. Having access to these videos is a real benefit to us all that may not be as mechanically gifted as some of our counterparts. Thank you for your support.
RetroCarGuy530
Discussion Starter #15
Subscribing to the RetroCarGuy530 LLC YouTube channel
Thank for taking the time to check out my videos!
You will always (unless Google changes something) be able to view my YouTube channel's videos with or without being subscribed to my YouTube channel.
All you'll need to do is click on the link for a particular video and that should take you to the video viewer on the YouTube website and it will play that video. You can then view any other video on my channel as well.
The ssrfanatic.com website was displaying a YouTube player within the post for the video on this site, but due to some recent change to the ssrfanatic.com website it stopped presenting that video viewer within the threads on this site. I've already reported that bug to the admins of this site and they are looking into it.
What does subscribing to my channel do for my channel:
Google / YouTube allows a channel to be monetized (capable of displaying ads during video playback) after a channel has reached a couple of minimum thresholds:
1000 subscribers
4000 watch hours (within the previous 12 months)
Once a YouTube channel reaches those minimums, the channel owner applies to be monetized. Once approved, the videos are allowed to present ads during video playback.
Google splits the revenue for the ads with the channel's owner. This is how the channel's owner can begin to make money from videos on their channel.
Of course, the channel owner has to be making video content people want to watch. The channel has to maintain the monetization minimums to remain monetized going forward.
How to subscribe to the RetroCarGuy530 LLC YouTube channel:
YouTube: Subscribe to the RetroCarGuy530 YouTube channel
Click on this link to go to my YouTube channel and have YouTube website present a popup panel that asks: "Are you sure you want to subscribe to RetroCarGuy530?"
If you already have a "Google" account all you have to do at this point is click on the "SUBSCRIBE" link on the page. (see attached photo)
If you're not signed in or don't have a Google account, you'll be presented with "Sign In" page from Google. (see attached photo)
If you have a Google account, simply sign in at this point.
If you don't have a Google account, you would click on the "Create account" link on that page. You'll then be presented with a "Create your Google Account" page where you enter in some info to create your new Google account. (see attached photo)
Once you're signed into your existing or new Google account you should be taken to my channel again (I believe). If it doesn't ask you to confirm the subscription to my channel, you can click on the link on this page again or click on the red "SUBSCRIBE" button(s) on my YouTube channel's page.
There is no cost to obtain the Google account nor is there any cost to subscribe to my YouTube channel!
I really wish there was a way to subscribe without a Google account, but I understand that Google has to track the items you as a viewer subscribe to, watch and your preferences for your YouTube viewing.
If my YouTube channel reaches the minimum monetization requirements, the video playback will get a bit more annoying to the viewers since ads will be presented during the video playback.
It should never cost you any money to watch my Chevy SSR videos!
If you've read this far into this post, thank you for your support!
-- Robert
RetroCarGuy530
Discussion Starter #16
I added the "Autel MaxiCheck Pro - Chevy SSR Smog Check Readiness" thread link to the first post in this thread.
RetroCarGuy530
Discussion Starter #20
I just went through all of the other forum threads for my YouTube videos to update any of them that were not displaying the mini YouTube player window. There was a ssrfanatic.com website change a while back that caused the YouTube links not to the display the mini player. After it was resolved on the website, the posts that had valid links still did not display the mini YouTube player.
I just edited/saved the posts that did not display mini YouTube player.
In doing so, the posts with "Likes" on them lost the "Likes" for the post because I technically edited the post, even though I didn't change anything.
Thanks for the "Likes" and I hope you can view the videos a little easier now.
The mini YouTube player is probably not the best viewing experience, but it at least gets you the thumbnail picture for the video and you can start watch the video using it and maximize the screen to make it easier to view.
You can also click on the title of the video at the top of the mini YouTube player and it will take you directly to the YouTube website to view the video.
Looking at the YouTube stats for my SSR videos over the past 28 days, 84% of the views are from non-subscribers.
I hope I'm providing helpful content to the SSR community. If you find it helpful, please subscribe to my RetroCarGuy530 YouTube channel (it's free). I'm including a link in this post that will take you to my YouTube channel and ask if you want to subscribe.
I'm attempting to get to 1,000 subscribers so I can meet the YouTube monetization requirements (allow ads to be displayed during my videos).
I'm near the end of my current computer software job and I'll be switching to the YouTube/Instagram TV channels full time to give it a solid shot at getting monetized and providing more helpful Chevy SSR content (as well as many other videos on other cars, car reviews, tool reviews, cars and coffee car meets, etc).
Thanks for your support in my next life adventure! :grin2:
YouTube - Subscribe to RetroCarGuy530 Channel
1 - 20 of 114 Posts
